ZTW SEAL G2 Series 160 v2 : OPTO 6s-14s : 160 amps : Lipo Brushless ESC
Following up on the success of the ZTW 300 g2, ZTW has released a 32-bit version of the Seal 160. The Seal G2 comes in a new compact design that is a full 100-gram lighter, shorter, and narrower than its predecessor.
The 32-bit Microcontroller supports the "CAN protocol" for recording data. The ESC can be programmed by the optional LCD prog card or the mobile phone APP (needs extra Bluetooth) and supports real-time data. More info will be coming.The ZTW SEAL G2 Series is designed specifically for RC Boat applications, featuring a waterproof design. The 160A ESC includes two water cooling pipes as well as customized heat sinks. However, the 160A ESC does not offer a built-in BEC, requiring an additional battery pack to operate the servo. To protect the boat, the ESC offers a power reduction when too hot and an optional Low Voltage Cutoff. For more specific information, see the specs below.Specs: The waterproof design (rates as IP 67) allows this ESC to work in wet conditions. Continuous Current (A): 160 Amps Burst Current(A): XXX AmpsVoltage: 6s - 14s Lipo (18-42 NiMH) Power Wire: 8 Gauge160mm-Red/160mm-Black Motor Wire 8 Gauge 160mm-Black Battery Eliminator Circuit (BEC): None, requires RX pack or BEC Eliminator Circuit. The throttle works in both forward and reverse or you can lock out the reverse function for racing safety.Optional programming with LCD programming card. Connectors: tx 90 on the battery side and 8mm connectors on the motor side. Case dimensions (not including wires): Length: 130mm (5.12") Width: 65mm (2.56") Height: 38mm (1.50") Weight: 530gWater fitting thread size: m6Includes: Everything in picture number one Note: This ESC will require an optional receiver battery pack or optional external BEC circuit. This ESC was designed to work in an environment where the ESC can get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater!! This ESC is recommended for boats in the 40" (1000mm) plus range. Because there are so many variables with each hull and installation it's impossible to specify all the applications for this ESC, if you have any questions about using this ESC with your particular boat, please contact us before purchasing.
