TFL P1 Aluminum outdrive system. This was returned from a customer, and never mounted, save $50.00. Titanium anodized coating/color. This High-quality CNC-designed drive system utilizes a set of straight gears and a drive dog-style coupler to the motor. Adjustable manual trim angle.Suggested for boats in the 25-35" range.Click here for a detailed drawing. Includes:Everything in the picture. (1) SSS 2960 Motor 2200kv (1) Outdrive(1) 36mm bronze propellerSpecs:4mm Prop Shaft. 385 Grams including motor. Note: Can be used in reverse with optional Right handed ABC, CNC or Octura props and ose-83400 adapter 4mm to 3/16". Require:Boat and (2) 2mm steering rods & (3) 4mm Female bullet connectors. 3s 40c 4000 to 5000 mah lipo pack
