5mm Thrust Bearing
Product ID boc-f5-11g
Price: $13.99
This 5mm thrust bearing will reduce motor heat by removing the pressure from the rear motor housing bearing in a brushed or brushless motor.
This will fit most motors with a 5mm output shaft.
We have these in 2 options
-Steel/metal balls
-Ceramic Balls
Measures:
5mm id x 11mm od x 4.5mm wide
1 Product Reviews - Average rating 5 / 5 (Show All)
Don't skimp on thrust bearings
Dan D - 25th January 2026
Giving how much thrust is being concentrated on thrust bearings, don't skimp on them and cheap out. I went with boca ceramic ones for my zonda with a pair of TP 4050 2100kVs. Lots of power on a small point.
