Quicksilver Premium Gear Lube SAE 80W-90 : Sale Normally $15.99
Product ID ama-802844Q02
In Stock 4
List Price: $17.99
Price: $12.99
This can be used in place of the MHZ recommended 1928 oil for the MHZ Outboards. Quicksilver engineers oil for marine applications. The high performance gear lube is formulated to provide excellent lubrication and corrosion protection to lower gear components in high-horsepower and high-speed outboards and sterndrives. Additives improve adhesion to gears and internal components to prevent metal-on-metal contact and reduce wear. Special emulsifiers have been added to prevent damage in the event that water enters the lower gear case. Protect the lower unit your high output engine with a lube designed for the extremes of marine use.
Features:
-Lower unit lube designed specifically for high-speed high-horsepower marine applications.
-Additives increase film adhesion to prevent metal-on-metal contact of gear and internal components.
-Emulsifiers have been added to protect internal components in the event that water enters the gear case
-Formulated to provide corrosion protection
Specs:
-8oz. Tube
-Viscosity SAE 90
Note: Packaging colors may vary, but all are the same Mercury SKU# 802844Q02
« Previous | Next »
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
