ABC Cleaver Series Reversed 3 Blade Propeller, .50 BarThese are .50 bar props, meaning they have less blade area than the .75 bar style ABC props.Attention! This prop is made for boats that require a clockwise spinning prop!
NUMBERING SYSTEM XXXX-XX-XX(X) XXX Example, 1817-23-50(3) CLL breaks down like this. 1.8 is the diameter in inches. 1.7 Pitch Radio 23-RAKE ANGLE 50-BLADE AREA RATIO (3)-NUMBER OF BLADES CL-CLEAVER OR CP-CHOPPERR-RIGHT ROTATION OR L-LEFT ROTATION. Shaft Size 3/16" (4.75mm)These also come in the opposite rotation for twin motor applications. See Product ID: abc-XXXX-23-50(3)CLL Note: Due to the longer-than-normal hub length, a longer prop shaft may be required.
