ABC 17-45 Series 2 Blade Cleaver Propeller
Product ID abc-XXXX-17-45(2)CLL
Price: $29.99
ABC Cleaver Series 2 Blade Propellers, .45 Bar
1.6 Inch (40.6mm) to 1.8 Inch (48.2mm) diameter props.
Shaft Size 3/16" (4.75mm) from 1516 to 2016.
Shaft Size 1/4" (6.35mm)from 2114 and larger prop diameters.
Available in three different pitches
1.5, 1.7 or 1.9 Pitch Ratio
 As pitch increases the blade angle increases.
How the ABC numbering system works.
XXXX-XX-XX(X) XXX
Example an 1815-17-45(2) CLL breaks down like this.
1.8 is the diameter in inches.
1.5 Pitch Radio
17-RAKE ANGLE
45-BLADE AREA RATIO
(2)-NUMBER OF BLADES
CL-CLEAVER OR CP-CHOPPER
L-LEFT ROTATION OR R-RIGHT ROTATION
These also come in the opposite rotation for twin motor applications. See Product ID: abc-XXXX-17-45(2)CLR
1 Product Reviews - Average rating 5 / 5 (Show All)
Nisana
Nila - 04th November 2022
Thanks
« Previous | Next »
ABC 17-45 Series Reversed 2 Blade Cleaver Propeller
1 of 2
Product ID abc-XXXX-17-45(2)CLR
Price$29.99
