Thrust Bearing
Product ID tfl-thrust-bearing
List Price: $5.99
Price: $4.99
A thrust bearing will reduce motor heat by relieving pressure on the rear motor housing bearing in a brushed or brushless motor, or used on prop shafts between the drive dog and strut.
Options:
- 4mm Shaft: 4mm id x 9mm od
- 5mm Shaft: 5mm id x 11mm od x 4mm wide
- 8mm Shaft: 8mm id x 16mm od x 5mm wide
- 1/8" Shaft: 3.175mm id x 8mm od x 3.5mm wide
- 3/16" Shaft: 4.76mm id x 10mm od x 4mm wide
- 1/4"   Shaft: 6.35mm id x 14mm od x 5mm wide
« Previous | Next »
