Coming fall 2024TFL Scale Outboard with Black CoverThis is the outboard system only. Includes:Motor TFL SSS F450 Outrunner 3000kvMotor diameter: Motor Connectors: Motor length: Shaft diameter: Propeller: 31mm diameter (3114310 3 Blade plastic) -Outboard Unit:xxmm from the bottom of the skeg to the top of the outboard cover. The cover is xx mm wide xxx Grams(approx) with a brushless motor. Drive: xxmm Propeller shaft, requires drive dog style propellers. Fits up to xxmm Prop Requires: - Everything besides the outboard unit.- Suggested ESC: Raider 90 esc. You will have to put the matching connector onto the esc. - 2s maximum, 40c 2000 to 3000mah lipo pack. - Propeller for 4mm prop shaft, which diameter prop will depend on the application.Notes:-IMPORTANT -Recommended for 18 (450mm) -22"(560mm) in the 1 Pound Range.-This is flex-driven and only can be used with left rotation(counterclockwise) propellers. -Standoff bracket xxxx may be required, depending on the application.
