TFL's small silver aluminum oil cup is designed to screw into T-bar stuffing tube mount and lubricate the stuffing tube while the boat is moving. See picture 3 for example. Specs:Length: 43mm (1.69")Diameter: 30mm (1.18")Threads into 6mm threaded hole.Note: Works with tfl-526b10 stuffing tube mount / bracket.
Pick up where you left off.
