Inline Catamaran Strut and Rudder System
Product ID tfl-502b20-2
Price: $29.95
TFL-502b20-2, Inline Catamaran Strut and Rudder Assembly
Inline aluminum rudder-and-strut system for Catamarans with built-in rudder water pickup. Features a nylon breakaway bolt on the rudder to reduce damage from impacts with submerged objects.
Mounting plate measures 30mm (1.18") wide x 24mm (.95") tall.
Leading edge of the rudder blade measures 87mm (3.42")
Offered in 2versions,
- .187"(4.75mm) Flex Cable with 3/16"(4.75mm) shaft, drive dog and bullet nut.
- Rudder & strut only. No Cable, no stuffing tube. This is for people with their own cables/shafts.
System Includes the following hardware:
(1) aluminum rudder
(1) aluminum strut with installed 3/16" Lead Teflon Bearing Sleeve.
Requires:
Requires customer to cut flex cable to required length.
Du-Bro 489 or 490 steering linkage connectors.
489 is for 2-56 linkage rod, 490 is much stronger 4-40 linkage rod but will require drilling the the hole larger on the steering arm.
Note: This is the second revision of this item. As of 10/25/2011, we have upgraded the strut to accommodate a larger prop and strengthened the strut barrel.
« Previous | Next »
Dual Pickup Rudder Blade for TFL Genesis 900, Zonda, Popeye, Apparition or ProMarine Skater
1 of 3
Product ID ose-83248
Price$19.99
