This SpeedMaster Center rudder assembly is made for large nitro and electric hulls 35" (900mm) or larger. High quality aluminum, CNC cut to tight tolerances. Comes with two built in water pickups for cooling esc and motor individually. The rudder and features a break away brass screw in the rudder bracket to help minimize damage from the blade hitting a object while driving. Comes with basic mounting screws. "T" Style mount makes this a great center mount rudder for Catamarans. The Rudder blade measures 6 1/4" long x 1 1/4" wide. Rudder blade is setback 1.75" (44.5mm. Setback measurement is from the transom to the front of the rudder blade. Mounting block measures 1.5" (38mm) Wide x 1.25" (31.8mm) Height.
