Speedmaster Dual Pickup Straight Blade Rudder Assembly
Product ID ros-spdr-012
Price: $49.95
This SpeedMaster rudder assembly is made for large nitro and electric hulls 38" or larger. High-quality aluminum, CNC cut to tight tolerances. Comes with two built-in water pickups for cooling esc and motor individually. The rudder features a breakaway brass screw in the rudder bracket to help minimize damage from the blade hitting an object while driving. Comes with basic mounting screws.
 The Rudder blade measures 6 1/4" long x 1 1/4" wide.
We offer this with 5 different brackets.
- Bracket with 1 1/8" of setback with L-style transom mount. (1st & 2nd picture)
- Bracket with 2" of setback with L-style transom mount. (1st & 2nd picture)
- Bracket with 4" of setback with L-style transom mount. (1st & 2nd picture)
- Bracket with 5" of setback with Tee style transom mount. (4th picture)
- Bracket with 6" of setback with Tee style transom mount. (4th picture)
Setback measurement is from the transom to the front of the rudder blade.
We also sell just the rudder blade itself. This can be used as a repair replacement instead of buying the entire rudder assembly.
Dual Arm Control Horn for Large Speedmaster Rudders 40/60
Product ID ros-spdr-018-da
Price$15.99
4-40 Linkage Rod (2.4mm diameter)
1 of 2
Product ID hh-4-40-3753
Price$1.99
Speedmaster rudder water fitting 10-32 thread
Product ID ros-spd-102
Price$2.95
Speedmaster Bearing Block Extension Bracket for Large Rudders Assembly
1 of 6
Product ID ros-bb-ext-lrg
Price$24.99
Speedmaster Short Transom Bracket for 40/60 Rudder Assemblies
Product ID ros-spdr-019-S
Price$6.99
Tee Bracket for Speedmaster for  Large Rudder Assemblies
1 of 2
Product ID ros-spdr-020-tb
Price$7.95
Linkage Rod Connector for 4-40 Rod
1 of 2
Product ID ose-83106
Price$2.49
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
