OSE ProBoat UL-19 heavy-duty flex cable assembly. This is for customers using a 6S Lipo power source or a modified ProBoat Ul-19 boat. This cable is made with a thicker gauge, .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 20% thicker than the stock ProBoat cable. This is cut and ready to install in your boat (requires ose-81518).
No soldering or cutting is required!
NOTE: This will NOT fit a Stock Ul-19 without the following additions.Requires: ose-81518 5mm to .187 Coupler and removal of stock Proboat Teflon liner.
Includes: OSE-cable-1190 Cable oct-oc6pnmm Bullet nutoct-oc6dmm drive dog.
