OSE, TFL Genesis heavy duty flex cable assembly. THIS ONLY WORKS WITH OSE-80975 3/16" Strut. This is for customers with a heavily modified TFL Genesis boats that are using 4074 and 4082 motors. This cable is made with thicker gauge .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 20% thicker than the stock TFL cable. This is cut and ready to install in your boat (requires ose-81518 & ose-80975).
No soldering or cutting required!
NOTE: This will NOT fit a Stock Genesis without the following additions. Requires: ose-81518 5mm to .187 Coupler and OSE-80975 Strut.
