OSE TFL Osprey 1 Piece Flex cable assembly.OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The flex cable on these is a thicker gauge for added strength. Installing these cables will make greasing the cables much easier than the stock cables. No soldering or cutting is required. Includes: (1) Ose-80248 tapered drive dog(1) Octura oc6pnmm prop nut(1) OSE-1190 Cable Measures:13.7" (348mm) from end to end
