ProBoat Miss Geico Zelos 36 Twin Flex cable assembly (Left and Right cable). OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The wire strands on this cable are a thicker gauge for added strength. No soldering or cutting is required.Includes:(1) Left and Right rotation cable with these parts installed.- Ose-80248 drive dogs- Octura oc6pnmm Brass Bullet prop nuts- Octura thin nuts NOTE: See picture 2 for which prop to use with which cable.A left rotation cable works with left-handed props, for example, prb282027, x442, x447A right rotation cable works with right-handed props, for example, prb282028, x442R, x447RProps not included. Measures:11.75" (298.45mm) from end to end
