OSE .150 cable with 3/16" to 1/8" stepdown prop shaft
Product ID ose-cable-1075
In Stock 5
Price: $29.99
OSE assembled .150" flex cable with Octura 3/16" stepped down to 1/8" Shaft for 1/8" propellers.
The shaft is made for 3/16"(.187') struts.
The propeller shaft measures 2 1/4" long(approx 57mm)
Measures approximately 24"(approx. 610mm) from tip to tip.*
The Includes:
Octura oct-oc61504ps Shaft
Octura oct-oc4d brass drive dog.
Octura oct-oc4pn Bullet Prop Nut
 .150 Teflon Liner.
Requires:
  • 1/4 OD K&S brass tubing for stuffing tube when used with the Teflon liner.
  • Cable cut to your desired length.
OSE .150 reversed (right) cable with 3/16" to 1/8" stepdown prop shaft
Product ID ose-cable-1075-R
Price$29.99
