Dual Pickup Rudder Blade for the ProBoat Voracity v2. NOTE: This fits the second generation Voracity v2. An easy way to tell the difference is the V2 rudder assembly has the nylon break away screw. See picture 1 to see if your blade has the same hinge area. Features: CNC machined billet aluminum construction and anodized in black. Rudder Blade Length 125mm Includes: Dual Pickup Rudder Blade Requires: Adding a second 1/4" water line (pn# ose-tubing-1/4-clear) and a water outlet. Installation of rudder & water line.
