OSE Dual Quick Change 40mm Motor MountDesigned similarly to our 40mm Single Quick Change Mount, this mount allows for twin motors with the quick-change motor clamp feature to easily remove the motors without having to fight to remove the front motor screws. The mount is also constructed of CNC Aluminum Front and Rear Mounting Plates, as well as 3 mm-thick Carbon Fiber Side Rails, to withstand the force of two motors. Features two front quick-change motor clamps (ose-83351).Can be used in a Mono or catamaran-style hulls. The aluminum front and rear clamps are 5" wide to fit standard nitro/gas boat hulls with 5" wood rails—for example, Delta Force Hulls. Can be used with any 40mm motor such as: Leopard 40series; TP 40series; SSS 40series; Neu 15 SeriesIncludes:(2) 3mm Carbon Side Rails(2) Silver anodized aluminum front and rear mounting platesSpecs:Length: 110mm (4.33")Width: 135mm (5.31")Height: 50mm (1.96")Weight: 99g (3.5 oz)Center to center of motor shafts: 70mm (2.76")
Video of Quick Change Feature.
