OSE Rudder for Traxxas Spartan with Dual Water Pickups
Product ID ose-83225
List Price: $39.99
Price: $34.95
Upgraded Dual Pickup Traxxas Spartan.
This is an effective way to add a second water pickup to your Traxxas Spartan.
Now you can run separate water lines to both the ESC and motor, resulting in better cooling. There are a lot of different ways to add a second water pickup to your boat, but all of them will add drag. That's why we developed our dual water pickup rudder blade. The dual water pickup rudder is a direct replacement for the stock rudder assembly, so we are not adding any extra parts to slow down your boat and reduce performance. A wider blade will help with lower-speed handling.
Includes:
Blue or Silver Rudder Assembly (everything in picture)
Requires: OSE 7/32 water cooling line. Anything thicker will not fit the fittings.
Specs:
Color: Anodized Blue or Silver Aluminum
Material: Aluminum
Blade measures 100mm from top to bottom.
Mounting bracket: 20 mm wide x 25 mm high.
Dual Water Outlet by Hot Racing
Product ID hh-spn28we06
Price$9.88
OSE Medium 7/32" Silicone Tubing
Product ID ose-tubing-7/32-clear
Price$3.49
