Use this to help get rid of water in your hull. The aluminum bailer has a small plastic ball that moves to allow water to exit your hull while the boat is moving, but when your boat is at rest, the outside water pressure pushes the ball into a seal that closes the hole. Measures:Approx 25mm long x 10mm diameter.
