Fiberglass, Water-cooled heavy-duty motor mount for 36mm motors. Fits 36mm diameter motors that are 60mm or longer in length. Both are water-cooled and adjustable. The rear motor clamp helps carry the weight of the heavier/longer 36mm motors. The angle is adjustable to allow straight alignment with the flex cable. The anodized aluminum mounting plate features extended fiberglass mounting stands that distribute the motor's weight over a larger area for added strength. The mounting plates have holes drilled in the bottom to allow the epoxy to flow into them to make a superior bond to the hull. This mount can fit a flat mounting area like a rigger or hydro, or a deep vee.
Applications: Fits most 36mm motors that are 60mm or longer. For example, Feigao, Nemesis, Hacker 540XL motors. Tp36xx, Leopard 3660, 3674 Will fit up to a 50mm long water jacket. Measures: Total width of 58mm, including the mounting stands.Metal center mounts measure 53mm wide. Fits 36mm diameter motors with a 19mm to 25mm mounting hole spacing, and M3 mounting screws. Requires you to provide motor mounting screws.Comes with a mount only. Motor and water jacket shown in pictures for display purposes only.
