CNC aluminum center mount rudder with a breakaway screw. Triangle center mount style works well with catamarans. Mount Measures: 28mm wide x 22mm tall Blade measures: -Top of blade mount to the bottom of the blade 115mm. -Leading edge of the blade itself 95mm.-Transom mount to the leading edge of the rudder blade 28mm.-Breakaway screw is 3mm
