OSE Charger Output Cable for OSE 6.0mm Bullet Connectors.
Output cable for any charger which uses 4mm bullet connectors in the charger. Over 12" (300mm) long, 12 ga silicone wire, two 4mm Male Banana Plugs attached one end, and OSE 6.0mm bullet connectors soldered on the other end. -Male OSE 6.0mm on positive end, Female 6.0mm on negative end.
