Brass Flex Ferrule: 1/4" Shaft to 1/4" Cable
This can be used with oct-oc68ps
Specs:- Outer diameter: 1/4" (6.375mm approx)- Length: 1.4" (35.5mm approx)
This is used when connecting a round 1/4" flex cable to a 1/4" propeller shaft. The cable can either be glued or soldered into the flex ferrule. You can read some info on the glue method here. The opposite end uses 2 grub screws to tighten the shaft to the flex ferrule.
