Octura .150 right cable with 3/16" prop shaft system for props that spin clockwise
Product ID oct-oc150R-24c
In Stock 3
Price: $14.99
Octura .150 Right lay flex cable with 3/16" prop shaft, drive dog, basic nut and teflon liner. Flex Cable is approx 22" Long.
The cable in this package is made for propellers that spin clockwise. For example, Octura props that end in the letter "R" or Graupner props that end in the letter "L".
Un-assembled, requires attaching the shaft to the cable with solder or glue. We also offer these assembled in the Flex cable assemblies category, click here.
Includes:
(1) Propeller Shaft oct-oc6150ps 2 1/4" (57mm)
(1) Drive Dog pn# oc6dmm
(1) Thin Prop Nut: pn# oct-n1032
(1) .150 Right lay Flex Cable approx 22" long
(1) .150 Teflon Tubing approx 22" Long : pn# oct-150T-24
Requires:
7/32 OD K&S brass tubing pn# 8130 for stuffing tube when used with the NO Teflon liner.
1/4 OD K&S brass tubing pn# 8131 for stuffing tube when used with the included Teflon liner.
Solder or glue the flex cable into the propeller shaft.
Set the drive dog and cut the flex to your desired length.
