These are hard to beat for the cost. Hobbywing UBEC 3A (2-6S Lipo Input) BEC, Eliminates the need for a RX Pack!! Tired of having a dead receiver pack ruin your day?Tired of buying AA batteries to power your receiver? Need to shed some weight from your Fast Electric? If you answered yes to any of those 3 questions you have found the right product. So you want to be free of the pains of running a Receiver (RX) battery pack? This BEC (battery eliminator circuit) product is for you. It uses your motor battery pack to supply the power to your receiver at upto 3 amps. Input voltage: 5v to 25.2v (2S to 6S LiPo)
Specs :
- Output Voltage: 5V@3A or 6V@3A (Changeable with an output-voltage select switch )- Continuous output current: 3 Amps- Input: 5.5V-26V (2-6 cells lithium battery pack or 5-18 cells NiMH /NiCd battery)- Size: 43mm*17mm*7mm (L*W*H)- Weight: 11g
Features:
- Designed with an advanced switch mode DC-DC regulator IC.- The output is powerful even working with 4 to 6 cells Lipo battery.- Battery polarity reversal protection.- A metal shield covers almost all the electronic components, and a specially made filter is attached with the output wires to significantly reduce the electromagnetic interference.- The working status is shown by an indicator (LED), lights when the output is in normal range.
This is a Battery Eliminator Circuit Only.Not a Motor Speed Control
