QUICRUN WP 880 Dual Brushed ESC, 2s-4s 80amps
Product ID ker-30120301
In Stock 2
List Price: $49.99
Price: $33.99
Brushed motor esc for dual motor boat, car, truck or crawler. For use with 2 motors at 40 amps each. 80 Amps total.
Features:
  • Fully waterproof design for all conditions. (Note: Please clean and dry it after use for avoiding rusty connectors).
  • HOBBYWING patented copper heat-conductive plates attached to the MOSFET board allows the internal heat to be quickly transferred to the aluminum heat sink for great heat dissipation.
  • Built-in switch-mode BEC with cont. current of 4A.
  • Tunable drag brake and drag brake rate for different vehicles, tracks, and control feel.
  • Adjustable PWM frequency combined with advanced freewheeling (/DEO) technology guarantees great throttle linearity and driving feel.
  • 9 levels of acceleration/ punch from soft to aggressive for different vehicles, tires and tracks.
  • Proportional brake with 9 levels of initial brake force, maximum brake force, and drag brake force.
  • Multiple protections: low-voltage cutoff protection, thermal protection, and throttle signal loss protection.
  • Separate programming port to easily connect the LED program card (purchase separately) to the ESC.
  • ESC programming via HOBBYWING LED Program Card (purchase separately).
Cont./Peak Current
80A maximum (40amps / motor)
Motor Type SupportedBrushed Motor (540, 550, 775 Size Motor)
Applicable CarVarious 1/10th & 1/8th Vehicles
Motor LimitBrushed Motor Limit with 2S LiPo /6S NiMH: ≥ 12T or RPM<[email protected] (540, 550 Size Motors)
Brushed Motor Limit with 3S LiPo /9S NiMH: ≥ 18T or RPM<[email protected] (540, 550 Size Motors)
Brushed Motor Limit with 4S LiPo /12S NiMH: ≥ 24T or RPM<[email protected] (540, 550 Size Motors)
LiPo / NiMH Cells
2-4S LiPo or 5-12S NiMH
BEC Output6V@4A (Switch-Mode)
ConnectorsInput End: No Connectors; Output End: 4.0mm Female Bullet Connectors
Size/ Weight45.9*34.7*26.5mm/ 75g
Programming PortSeparate Port
WaterproofWaterproof
Note: WP-880-DUAL BRUSHED ESC has two outputs to drive 2 motors. When driving 2 motors simultaneously, the Turn of the motors needs to be increased.
« Previous | Next »
Hobbywing program card for SeaKing Boat ESC's
1 of 2
Product ID ker-seaking-pcard
Price$9.99
