Infrared Temp Gun/Thermometer with Laser Sight Point and click! That's all that it takes to figure out the temperature of your brushless motor, nitro engine, esc or batteries. This is a tool every electric or nitro hobbyist should carry in their tool box!
Wireless for safe and accurate readings without touching the heat source-simply point, push a button, and read the results.Specs: - Compact, rugged, easy to use - Temperature Range: -58F to 716F (-50 to +380C) - Accuracy: +/- 2% or 2C - Resolution: 0.1C (0.1F) - Response Time: 0.8s - Emissivity: 0.95 fixed - Distance to Spot Ratio: 12:1 - Spectral Response: 5-14um - Storage Temperature: 20 to 50C /-4 to 122F - Operating Temperature: 0 to 50C/ 32 to 122F - Power: 9V Battery (Included)
