Hot Racing aluminum adjustable trim tabs for the Traxxas DCB M41 boats Features: - Adjusts angle of trim tab assembly for proper hull planing - CNC machined aluminum construction - Pre-drilled for mounting - Anodized blue for durability, corrosion resistance, and great looks Includes: - Two (2) adjustable trim tabs S Specs: - Weight: 0.78oz - Length: 33mm (1.30 inch) - Width: 30mm (1.18 inch) - Height: 24.5mm (.96 inch) Note: - Use the stock 4x12mm screws to mount
