Delta Force DF45 MK-ll Fiberglass Boat Hull. These lightweight fiberglass boats are built for Fast Electric Rc Boat Racing. Designed as a deep vee with a small rear pad makes this boat handles well and achieves a very good top speed. The hull and deck are joined leaving only a minimal pencil-width seam, similar to the European-designed hulls. Specs:Size: 980mm (38.5") x 290mm (11.4") x 95mm (3.9") Weight: 1600g (3.52lb) approx Material: Fiberglass Comes as a bare hull. Basic Power & Hardware Recommendations: 6s to 8s Lipo Leopard 4092, Neu 1527, Tp-4060 or larger-sized motors. Hardware: Speedmaster Stinger 3/16" Size, Speedmaster dual pickup rudder 4" setback Note: Picture 1 shows the hull with the scoop on the hatch/cowl. The scoop is a user-installed item.
