OSE CNC High Rake Series Props : Stainless Steel : Reverse Rotation
Product ID cnc-HS-xx16-R
List Price: $59.99
Price: $49.99
OSE HS Series Cleaver 2 Blade Propellers in Reverse(right) rotation, machined out of Stainless Steel.
CNC Computer machined to a high tolerance for use out of the box. No modifications are needed.
Specs:
Diameter options: 42, 45, 48, or 52mm
Rotation: Right (See picture)
1.6 Inch pitch ratio.
Shaft Size 3/16" (4.75mm).
ATTENTION: Right-hand rotation. These spin clockwise when looking at them from the back of the boat. Used for twins or boats that require opposite rotation than normal.
NOTE: When used with Zonda GT or similar powered, these are high amp draw. These are for a few seconds of use for drag-style use. These will push parts hard. If you are worried about burning things up, these are NOT the props for you. Go smaller or stay stock.
1 of 2
Price$49.99
