CNC 5214-R Reversed Magnalium 7075 propeller. Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum. ATTENTION: Right and rotation. These spin clockwise when viewed from the back of the boat. Used for twins or boats that require opposite rotation than normal. Fits 3/16"(.187" 4.76mm) Smooth Bore Propeller Shafts.
