CNC 4216 1.6 Pitch 3 Blade Reversed Cleaver Prop, Magnalium 7075 propeller. Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum. ATTENTION: Right and rotation. These spin clockwise when looking at them from the back of the boat. Used for twins or boats that require opposite rotation than normal. Fits 3/16"(.187" 4.76mm) Smooth Bore Propeller Shafts.
