CNC 3414-R Reversed Magnalium 7075 propeller. Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum. ATTENTION: Right and rotation. These spin clockwise when looking at them from the back of the boat. Used for twins or boats that require opposite rotation than normal. Fits 1/8"(.125" 3.17mm) Smooth Bore Propeller Shafts. Diameter Total Pitch 34mm (1.34") 1.88"
