CNC 3214 3 Blade Magnalium 7075 propeller. Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum. Left-hand rotation. These spin counterclockwise when looking at them from the back of the boat. Fits 1/8"(.125" 3.17mm) Smooth Bore Propeller Shafts.
NOTE for Traxxas Blast:Requires Octura oct-ocgcss4 upgrade shaft to fit onto Traxxas Blast. Larger props will also require closer monitoring of motor and ESC heat.
