Wire a High voltage servo with a receiver and esc that can only take the normal 4.5 - 6.0 volts.
Published
13th October 2023
Wire a High-voltage servo with a receiver and ESC that can only take the normal 4.5 - 6.0 volts.
By using a second pack to power just the servo, you can run hv servos with receivers that are not hv compatible. See diagram.
