ABC Cleaver Series 3 Blade Propeller, .50 Bar
We have these in sizes ranging from 1.5" (38mm) Diameter to 2.6" (66mm) Diameter. These are .50 bar props, meaning they have less blade area than the .75 bar style ABC props.
NUMBERING SYSTEM XXXX-XX-XX(X) XXX For example a 1614-10-50(3) CLL breaks down like this. 1.6 is the diameter in inches. 1.4 Pitch Radio 10-RAKE ANGLE 50-BLADE AREA RATIO (3)-NUMBER OF BLADES CL-CLEAVER OR CP-CHOPPER L-LEFT ROTATION OR R-RIGHT ROTATION. NOTE: Shaft Size 3/16" (4.75mm) from 1516 to 2318. Shaft Size 1/4"(6.35mm)from 2616 and larger prop diameters. These also come in the opposite rotation for twin motor applications. See Product ID: abc-XXXX-10-50(3)CLR
