TP Power SVM Series Brushless 4080 Motor (measures 40mm x 117mm) for high rpm short-use applications, for example, drag racing. Special while supplies last! Water Jacket included with TP Motor Purchase!
These are designed for RC boats, trucks, or cars that are running high-speed straight-line competition. NOT for long run times. These are hand wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Suggested use for drag style applications:-2400Kv 8s Version, 34.0v maximum for 10 seconds or less. -3600Kv 6s Version, 22.0v maximum for 10 seconds or less.
Specs:Magnets: Neodymium Watts continuous: 6000 Watts max: 11000 for less than 10 seconds Poles: 4 Motor Shaft: 8mm with flat spot. Can Measures: 40mm diameter x 117mm longApprox weight (varies with wind choice): 750 Grams Mounting screw diameter required: 3mmMounting Holes 25mm apart
REQUIRES: Bullet connectors. We suggest the OSE 8mm Bullets, QS6 or Castle 8mm Connectors. NOTE: This is a competition motor. Due to the high strain of pushing equipment when racing, there is no warranty on this item.We suggest if you do not have the experience to be able to select the correct motor, please consult OSE first or other members of the RC fast electric boating community. Either at your local boat club or on our OSE Forum.
