TP 4050 Power SVM Series Brushless Motor. New competition 4-pole motor with more torque and power under high RPM design. 4050 V1 Motor (measures 40mm x 82mm). Best suited for high rpm in short-use applications, for example, drag racing. Special while supplies last! Water Jacket included with TP Motor Purchase!
These are higher output than the tp-4050, they are rated to run up to 91,000rpm for 10 seconds or less. These are designed for running at high speed in straight-line competition. NOT for long run times. These are hand wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Suggested use for drag style applications:-2580Kv 8s Version, 34.0v maximum for 10 seconds or less. -32600Kv 6s Version, 23.5v maximum for 10 seconds or less.
Specs:Magnets: NeodymiumWind: Delta Watts continuous: 3000 Watts max: 6400 for less than 10 seconds Poles: 4 Motor Shaft: 8mm with a flat spot. Can Measures: 40mm diameter x 82mm long Weight: approx: 450 Grams(diff winds will be more or less weight) Mounting screw diameter required: 3mmMounting Holes: 25mm apart.
REQUIRES: Bullet connectors. We suggest the OSE 8mm, QS8, or Castle 8mm Bullets. NOTE: This is a competition motor. Due to the high strain of pushing equipment when racing, there is no warranty on this item. We suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the RC fast electric boating community. Either at a local club or on our OSE Forums.
