Fully adjustable 40mm diameter motor mount with carbon stands.
Product ID tfl-523b63
List Price: $49.99
Price: $29.99
This is for mounting a motor on a flat surface, for example riggers, cats and hydros. The higher fiberglass stands allow more clearence for the water jacket. Sliding rear mount allows for many length motors and water jackets.
Fits 40mm diameter motors that are 60mm or longer. Examples: TP 40xx, Leopard 4074, 4082, and 4092 brushless Motors.
The angle is adjustable to allow straight alignment with the flex cable.
The anodized aluminum mounting plate with extended fiberglass mounting stands to distribute the weight of the motor over a larger area for added strength. The mounting plates that have holes drilled in the bottom to allow epoxy to flow into them to make a superior bond to the hull.
Applications:
Fits most 40mm motors that are 60mm or longer.
For example,  Tp40xx, Leopard 4065, 4074, 4082, and 4092
Requires you to provide motor mounting screws.
Comes with mount only.
Tenshock Evo 2250 "High Power" Version (40mm x 79.5mm long)
1 of 3
Product ID ten-evo-2250-HP
Price$259.99
Tenshock Evo 2260 "High Power" Version (40mm x 90.0mm long) :
1 of 3
Product ID ten-evo-2260-HP
Price$279.99
Tenshock Evo 2270 "High Power" Version (40mm x 99.5mm long) :
1 of 4
Product ID ten-evo-2270-HP
Price$319.99
Tenshock Evo 2280 "High Power" Version (40mm x 109.5mm long) :
1 of 4
Product ID ten-evo-2280-HP
Price$359.99
