Scale-looking aluminum center mounting rudder. We would suggest this blade length/size for a boat in the 32" (800mm) to 42" (1050mm) range. This is the same bracket as the 502b38 but with a longer 100mm blade.Designed to be used with the tfl-502b38-02 scale-looking hydraulic steering linkage system for a real-looking Offshore Racing style system. The triangle center mount style works well with catamarans. Includes a brass breakaway screw to help minimize damage from the blade hitting an object while driving. TFL Center Mount Rudder: MediumMounting Bracket Specs:Width: 28.575mm (1.125")Height: 19.05mm (0.75")Blade measures:Leading Edge: 100mm (4")Total Depth: 125mm (5")
Includes:(1) Center Mount Rudder Assembly(2) Hydraulic Linkage Cables pn# tfl-502b38-02 Linkage Specs: Length: 330mm (13") Requires:Servo arm and clevis Note: Boat not included. The boat in the picture is the TFL Genesis 1122.
