TFL Cheetah XL RC Boat: Fiberglass Twin Hardware Setup. Available in white or yellow. NO Windshield Decal NOTE: Picture shows esc and motors. THIS IS A HARDWARE ONLY Version. NO motors and NO esc's. Now includes an optional Kevlar inlay for added strength.TFL has designed this hull to be both fast and agile around corners. All pieces are either fiberglass, carbon fiber, or aluminum to withstand the force at such high speeds. With the right setup and tuning, this setup can reach speeds close to 70mph and above. Specs: Propeller Shaft: 3/16" Propeller shaft for use with all the popular propellers on the market Cables: 1 Piece cables 3/16" flex diameter.Strut: Adjustable stinger struts Flush mount bottom hull water pickups, see picture 5Rudder Assembly: Double Water pickup rudder assembly with 120mm leading edge and breakaway screw. These are not utilized and need to be blocked off if the builder decides not to use them. Battery trays: Adjustable Carbon fiber trays Coupler: 5mm - .187 coupler ESC: None Motors: None Propellers: None Hull Specs: Length: 1010mm (39.75") Beam: 150mm (5.90") Width: 380mm (15") Requires: (1) Radio System (1) Servo (2) 4s or 6s Lipo Packs (2) Motors (2) Esc's Recommended Setup ESC: (2) ZTW 200A ESCs with 6mm bullet connectors on motor side and QS6P connectors on the battery side. Motors: SSS 4092, Leopard 4092 or tp-4060 motors in the 1600-1800kv range. NOTE: Windshield for display only. Comes with no windshield
