$199 while supplies last.
Evo TS-MI-EVO2260 38x90mm) 6 Pole Motor by Tenshock. -See picture 2 for motor chart1. Powerful 6-pole core design for high torque output.2. Advanced assembly technology enables more efficient space utilization.3. CNC machined aluminum casing4. Silver windings for higher efficiency.5. Powerful sintered neodymium magnets6. High torque torque-to-weight ratio.7. The hand-wound weaving of the winding ensures the motor has excellent electrical characteristics! 8. Include a water jacket with an internal water channel to ensure water flows around the motor 9. High grade bearingsSpecs:Magnets: neodymiumWatts: 6500Poles: 6Motor Shaft: 5mmShaft Length: 15mmCan Measures: 38mm diameter x 89.50mm longWeight: 440 GramsMounting Screw diameter required: 3mmBearing size: 5mm x 14mm x 5mm Connectors: 5.5mmOSE Suggests 30,000-40,000 total rpm. These are only guidelines, we suggest if you don't know how to pick the correct motor, please consult OSE first or other members of the RC Fast electric boating community, either at a local club or on our OSE Forums.
