Speedmaster 1/4" CAT Strut Assembly Round Bottom
Product ID ros-spds-011-250R
In Stock 2
Price: $34.95
1/4" CAT Strut Assembly Round Bottom with 1/4 Brass Bushing
These can be used on Hydros, Riggers, or Catamarans of 40" or greater. Made with high-quality aluminum, CNC cut to tight tolerances. These come with a cross-drilled strut bushing for .250 (1/4") prop shafts.
Made in the USA!
You may have seen this strut elsewhere for a lower cost, the difference is OSE packages these with the brass bushing which most all the other companies out there DO NOT!
Requires:
 .250(1/4") Strut requires K&S# 8133 5/16" brass stuffing tube.
