Anodized servo mount for standard-size servos(for example Futaba S3003 etc.). Screws included. Servo NOT included.
Notes: For use in a RC boat this will require either screwing threw the hull, gluing it directly to the hull, or a wooden base to screw into. Some servos will require slight modifications if there are bulges or wires sticking out of the sides. Will fit up to 43mm wide servo. Measures: Footprint is 70mm x 20mm (see picture 4)Will fit upto a 43mm wide x 22mm tall servo
