Aluminum cnc water pickup fitting with dual inlets. This water fitting is designed to be installed onto the transom for quick and easy installation. It allows the constant flow of water that your boat is riding on to travel up and into your water system. Dual inlets allow individual cooling to your esc and motor. This can be used with 1/4" silicon tubing we sell part# ose-tubing-1/4-clear. SpecsWidth: 21mm(.83")Height: 20.5mm (.81")Outlet Size: M4
