Offshore Electrics upgraded strut for the V3 versions of the ProBoat Miss Geico 29 V3 and BlackJack 29 V3. This OSE CNC aluminum strut uses two Octura lead/teflon bushings to support the 3/16" prop shaft. These bushings run much smoother than the stock ProBoat bronze metal bushings. The ProBoat bronze bushings heat up and cause binding and broken cables. Includes: (1) Silver aluminum strut (2) Installed Octura pn# oct-oc6ltsb 3/16" bushing Notes: This item can be used in the V1 versions of the ProBoat Mystic, Geico 29, Blackjack 29, and BJ29 with some basic modifications. - The stuffing tube in a v1 is 6mm. The stuffing tube in a V3 is 6.3mm, you would have to fill the extra space or cover the strut bullet with the included shrink wrap. This helps prevent water from coming up the stuffing tube. - The V3 mounting slot is longer than the V1. This doesn't affect its use in a v1.
