Neu 1536 Motor 0.75DKv 2200This is for 7-9S Rc drag cars. Not for boats!!!Specifications:Click for Neu Motor Chart Specs: KV Options: 2200Smooth CanWeight: 825 grams (approx) Diameter: 40mm x approx Length: 5.15" (130.7mm approx) Number of Poles: 4 Motor output shaft size: 8mm Requires: 3mm or 4mm mounting screws. Fits most 40mm motor mounts with 25mm mounting hole spacing.
Requires:Mounting Screws and connectors.
We if you don't see the motor wind listed you need or need special options, we can special order from the entire Neu Motors line up. Contact us for more details.
