Spektrum 2400Kv, 36x60mm, 4 pole Brushless Marine Motor with water jacket.
The Spektrum 2400Kv Brushless Marine Motor is the perfect option for high-end racing boats with a 3S-4S LiPo powered setup. This motor was designed to produce maximum power while meeting all NAMBA racing rules. This 2400Kv motor is water-cooled for lower operating temperatures and higher performance. It also features a 4-pole design, a high-quality alloy steel 5mm output shaft, and 4mm bullet connectors for easy installation.
Works with the following in 3S-4S configurations:PRB08051 - 1/6 24" Jetstream Jet Boat RTRPRB08041V2 - Recoil 2 V2 26" Self-Righting Brushless Deep-V RTRPRB08037 - Impulse 32" Brushless Deep-V RTR with SmartPRB08032V2 - Sonicwake V2 36" Self-Righting Brushless Deep-V RTRPRB08049 - Blackjack 24" V2 Catamaran Brushless: RTR
Specs: RPM: 2400Kv Shaft Size: 5mm Mounting Screws: m3 Motor Length: 60mm Motor Diameter: 36mm Motor Weight: 304 grams(includes weight of jacket)Water Jacket Diameter: mm Mounting Holes 25mm apart
